查看: 709|回复: 0
IEC 60754-3:2018 Measurement of low level of halogen content by ion chromatograp
发表于 2018-1-20 10:58:24 | 显示全部楼层 |阅读模式
IEC 60754-3:2018 Test on gases evolved during combustion of materials from cables - Part 3: Measurement of low level of halogen content by ion chromatography
IEC 60754-3:2018 specifies the apparatus and procedure for the measurement of the amount of halogens evolved during the combustion of materials taken from electric or optical fibre cable constructions. The method specified in this document is intended for the measurement of the content of chlorine (Cl), bromine (Br), fluorine (F) and iodine (I), by using the analytical technique of ion chromatography for analysing an aqueous solution resulting from the gases evolved during the combustion.
The heating (combustion) procedure in this part of IEC 60754 is the same as in IEC 60754-2. The method is intended for materials with an individual halogen content not exceeding 10 mg/g. The method specified in this document is intended for the testing of individual components used in a cable construction.
The use of this method will enable the verification of requirements which are stated in the appropriate cable specification for individual components of a cable construction.
For reasons of precision, this method is not recommended for detecting values of halogens less than 0,1 mg/g of the sample taken.
Publication date        2018-01-12
Edition        1.0
TC/SC        TC 20 - Electric cablesrss
ICS        29.060.20 - Cables
13.220.40 - Ignitability and burning behaviour of materials and products
Stability date          2021
GMT+8, 2024-5-8 22:32 , Processed in 0.031785 second(s), 5 queries , Gzip On, Redis On.
