查看: 848|回复: 0
IEC 62055-41:2018 STS Application layer protocol for one-way token carrier syste
发表于 2018-1-20 11:25:31 | 显示全部楼层 |阅读模式
IEC 62055-41:2018 Electricity metering  - Payment systems - Part 41: Standard transfer specification (STS) - Application layer protocol for one-way token carrier systems
IEC 62055-41:2018 specifies the application layer protocol of the standard transfer specification (STS) used for transferring units of credit and other management information from a point of sale (POS) system to an STS-compliant payment meter in a one-way token carrier system. It is primarily intended for application with electricity payment meters without a tariff employing energy-based tokens, but may also have application with currency-based token systems and for services other than electricity.
It is intended for use by manufacturers of payment meters that have to accept tokens that comply with the STS and also by manufacturers of POS systems that have to produce STS-compliant tokens and is to be read in conjunction with IEC 62055-5x series.
This third edition cancels and replaces the second edition of IEC 62055-41, issued in 2014.
It constitutes a technical revision.
The main technical changes with regard to the previous edition are as follows:
- currency transfer tokens for electricity, water, gas and time metering;
- common code PAN for 2 and 4 digit manufacturer codes;
- reserved MfrCode values for certification and testing purposes;
- provision for DLMS/COSEM as a virtual token carrier type;
GMT+8, 2024-5-7 08:10 , Processed in 0.019646 second(s), 5 queries , Gzip On, Redis On.
