查看: 5448|回复: 24
ASTM E140-2007 硬度换算表
上海市
发表于 2021-1-22 14:16:39 | 显示全部楼层 |阅读模式
ASTM E140-2007硬度换算表.pdf
Standard Hardness Conversion Tables for Metals Relationship Among Brinell Hardness, Vickers Hardness, Rockwell Hardness, Superficial Hardness, Knoop Hardness, and Scleroscope Hardness
This standard is issued under the fixed designation E 140; the number immediately following the designation indicates the year of original adoption or, in the case of revision, the year of last revision. A number in parentheses indicates the year of last reapproval. A superscript epsilon (e) indicates an editorial change since the last revision or reapproval.
This standard has been approved for use by agencies of the Department of Defense
141.18 KB, 下载次数: 65
售价: 7 品质币  [记录]
ASTM
发表于 2021-1-22 17:19:42 | 显示全部楼层
谢谢分享!
发表于 2021-1-22 18:36:45 | 显示全部楼层
发表于 2021-1-22 21:40:39 | 显示全部楼层
謝謝分享
发表于 2021-1-22 21:43:02 | 显示全部楼层
thanks
发表于 2021-1-23 08:22:56 | 显示全部楼层
发表于 2021-1-23 09:31:31 | 显示全部楼层
发表于 2021-1-23 09:50:34 | 显示全部楼层
发表于 2021-1-23 10:45:51 | 显示全部楼层
謝謝分享
发表于 2021-1-23 10:48:15 | 显示全部楼层
謝謝分享
GMT+8, 2024-4-27 19:14 , Processed in 0.033138 second(s), 6 queries , Gzip On, Redis On.
