查看: 11080|回复: 40
我在美国总部经历的SQE处理质量问题全过程(汽车)转载
VIP会员
Rank: 6Rank: 6
发表于 2021-3-11 19:38:39 | 显示全部楼层 |阅读模式
首先说下问题背景,汽车行业,球铁铸件,在客户车辆上发生断裂,我会实时更新处理过程,及最新的进展由于时间问题会用英文,请大家谅解了,主要是记录下美国SQE 处理问题的思路与咱们有什么细节上的不同,及问题分析全过程。。我会有中文说明的
1。containment action requiement 1/8/3013
Here is more detail of the break slack body.
• Date code on the metal side cover is **********
• The casting identification is QB4 ( Qianbao, casting position 4) and 12C08 (batch/lot code).
Immediate containment actions require
• Quarantine all the slacks (from coming to US, Finish Assemblies and current inventory in the plant and at suppliers)
Need an answers to the following questions within next 24 hrs. (if possible, someone has to visit the supplier ASAP)
Interoperation of “12C08 and QB4”
When and How many parts product in the same batch?
Send Material Certificate for the same batch including the nodularity results.
How many parts were fail for nodularity in general (during the mfg. process)?
What process DOEs supplier use to ensure ductile iron? (Control plan, process flow and visual aids)
How long does its change last and what alternate system do they have?
8月2日 更新
     解释几个疑问,0km发现的,不是使用不当造成的。供应商是国内,昨天国内的SQE去供应商了解了下过程,铸铁的某种含量不符合要求,但是这些铸铁不是用在我们的产品上。这个情况还没跟美国人说,只私下里和我沟通了一下,就我所知美国人他们很相信供应商,相信供应商不会作假。但是好像不怎么相信我们自己处理这件事情并给他们回复,非要亲自来处理。难道我们会骗他们么?
    另外,我也很关心他们的lesson-learn与别供应商分享。貌似咱们一般都没有这一步?
     目前的决议是,美国人要求需要供应商的control plan 和FMEA, 下周直接飞来到供应商处审核过程查找原因(这个美国人是质量经理)
以下是他们的邮件
Hello,
Due to the high importance of this issue, it was decided that I come to Dalian right away to evaluate the issue. While I am there, I would like to prioritize a visit to this supplier to understand what happened and what part of their controls failed. We will be able to share or finding also at this point. If you could manage to get a copy of their control plan and FMEA ready it would be greatly appreciated. I would also like to visit the second casting supplier to evaluate their processes and to implement lesson’s learned for the supplier that shipped the rejected part.
This issue is of the greatest concern in order for us to be respected as a global slack adjuster supplier. Having this defect will prevent us from doing so at the start of the market introduction and prevent us from being successful. Let me thank you ahead of time for your support as we go through this process.
8月5日更新
     前两天周末,没有什么动态,美国人已经到了中国,并且准备在今日或明日去供应商处验证分析,真没想到在他临走前和他聊天,以下聊天内容(大体内容)。
我:先生,出了这么大质量事故,你怎么还这么高兴(开玩笑的说)
美国人:因为我要去中国了,可以到你们的城市购物了
我:呵呵,你应该是去解决问题的,帮我们解决问题是第一重要的
美国人:是的,我的工作任务是去解决问题,并且我也以我能去帮助解决问题而高兴,我好久没有涉及亲自去解决调查问题了,所以我因为这点我也很高兴。你想想,如果我成功的解决了问题并且回复了客户,客户很认可我们的回复,并且因为我的回复而挽回了损失,我应该高兴不?所以我就要带着高兴的心情去你们那疯狂的购物,而且便宜的很,质量也不错。我为什么不高兴呢?
我::呵呵,先生,你真的认为会很顺利的解决么?并且很彻底的解决?因为你语言不通,等诸多因素。不要高兴的太早偶?
美国人:我确信语言不是问题,我有很棒的同事会帮助我,并且我坚信我们的供应商会很喜欢和我交流并解决问题,据我所知他们很和善,我很有自信这些都能够解决,并且他们作为铸造专业厂家对这样的问题很有经验,自己出现了问题会很快和我一起找到原因并解决。那样对于他们和我们的合作会更加深入下去,他们不会不知道这些好处的
我:先生,我明白你的心情了,如果是我的话,我会很着急根本没心思干别的,而且我会对供应商很失望,并且会生气,呵呵,没想到你面对供应商出现问题时会这么想。可能是我们中国和你们的思维和文化部同吧。我真心希望能和你去一起去解决问题,以中国的角度和你们的角度一同分析解决,看一下结果如何。
美国人:呵呵,希望会有这样的机会,我到担心一件事,就是我的睡眠问题24小时的时差。。。。
我:祝你旅途愉快
呵呵,以上内容请大家发表感想吧。他们的想法是不是和我们不一样?
目前我正在分析他们的铸造工艺及美国人的建议,稍后我看看有没有必要把他们的铸造过程发布出来,希望强人们帮忙分析啊
8月7日更新
前2天没什么进展,美国人和我们SQE花了一天时间在供应商处审核,今天或明天准备开三方电话会议通报结果和进一步的措施,我会及时公布会议内容,及分析结果。
以下是我们的SQE在美国人去之前对该供应商的预审,并针对前面的提问的回答,以及美国人的追问
(邮件内容):
Dear sir,
1.We block 5824pcs finished product in our warehouse waiting for sort out assembly by QB body.
2.973 pcs QB body in our warehouse had been blocked. Mr.Shi Lianyi already informed QB stop no more production and block all the body in their warehouse waiting the analysis results.
This afternoon Lianyi and I went to QB supplier, and below is the investigation for the questions.
# Interoperation of “12C08 and QB4”
This broken ASA casting data: 2012/03/08, casting position is 4. Supplier: QB
# When and How many parts product in the same batch?
606pcs body cast in 2012/03/08.
# Send Material Certificate for the same batch including the nodularity results.
Material certificate please see attached test reports.
# How many parts were fail for nodularity in general (during the mfg. process)?
For our body have 3 batches failed for Nodularity. (2012/03/14 failed 128 pcs ,2012/04/09 failed 80 pcs ,2012/04/23 failed 44 pcs)
We also found one oven iron Nodularity unqualified on 2013/03/08( the same batch as the broken ASA ) , the record(please see attached second file) from supplier show the unqualified oven iron did not used for our body, it used for another company products.
# What process does supplier use to ensure ductile iron? (Control plan, process flow and visual aids)
The supplier makes the modularity test for testing model from every pouring ladle. They also record the test results. The supplier keeps these testing models half a year on their site.
They make this standard process in control plan. We will translate these documents to you tomorrow.
Thanks for all your supports!
美国人回复的邮件
Hello Qingsong,
Thank you for your support in this matter.
Unfortunately with the results of your findings, I now do not have confidence in this supplier. Controlling nodularity should be basic for an iron foundry and there should never be any internal failures. It appears to me, having rejects is common. If you could reply, I have more questions now on their process.
1) What type of method do they use to measure nodularity? Is it microscope examination of the last pIECe or UT testing?
2) If microscope examination, how do they know how far to go back with the pieces to pull out the bad ones?
3) How would the supplier keep the samples in order so as to sort out good /bad parts?
4) You mention in your e-mail that this lot was not qualified. What exactly does that mean. Did the whole lot fail? How many pieces failed in that lot of the one we received and how did they quarantine the out of spec product? Do they have a check sheet that would account for the failed units?
5) How did the piece we received leave their facility? If you can determine root cause, is there a way to predict how many escaped (with extreme accuracy).
We have also stopped shipping to our customers and we are ready to sort product using UT tester. We need to get a complete understanding of the issue as soon as possible.
Thank you again,
ken
名词解释:nodularity (石墨形态,核的形态,一钟铸铁的微观组织形态)microscope 显微镜 iron foundry 铸铁厂 quarantine 隔离
铸造过程
1 原材料检验 各种化学分 10 生铁 GB1412-85
仪器 11 回炉料 分析报告
12 废钢 无杂物
13 球化剂 GB3649-87
14 孕育剂 GB2272-87
15 模具检查 浇冒系统表面标记完整
2 制芯 射芯机 20 壳厚 ≥8mm
21 颜色 褐色
22 外观 无毛刺缺肉
3 砂处理 30 型砂含水量 3.0-3.8%
31 型砂透气性 >80
32 型砂强度 1.0-1.4Mpa
4 造型 造型线 40 型腔硬度 80-100
41 错箱量 <0.5mm
5 熔炼 电炉 50 材料配比 ▲ 配料规范
51 温度 1520-1530℃
52 化学成份 ▲ SAE J434 D4512 C 3.5-3.9 Si 2.7-3.0 Mn<0.5 P<0.07 S<0.03
53 CE 化学成份标准
球化包 54 球化率 80%以上(包尾三角试片)
55 球化剂加入量 1.0-1.2%
56 除渣 包面无渣
6 浇注 吊包 60 二次孕育 孕育剂0.05-0.1%
61 浇注速度 ≤8分钟
7 落砂 70 符合检验作业指导书
8 转移 80 划痕 符合检验作业指导书
81 搬运 运送标识
9 清理 锤子 90 划痕 符合检验作业指导书
91 断口检查 球化率≥80%
抛丸机 92 毛坯表面质量 检验作业指导书
砂轮机 93 磨浇口毛刺 无毛刺
抛丸机 94 毛坯 无粘砂
10、 喷淋 100 毛坯 冲洗 常温、清水
浸入 磷化槽 101 磷化处理 时间3-5分钟、温度35-40℃
电泳前喷淋 102 冲洗 两次 一次纯水常温
二次纯水常温
电泳 电泳槽 103 时间 作业指导书
温度 作业指导书
固体分 作业指导书
电压 作业指导书
PH值 作业指导书
电导率 作业指导书
电泳后喷淋 104 冲洗 外观
电导率 作业指导书
烘烤 105 干燥 温度
11、 最终检验 110 外观 符合铸件检验标准
111 尺寸 尺寸符合图纸要求
解剖 112 缩松 ASTM E446 A区3级以上
12 包装 仓库 120 成品 装箱 数量控制
121 分层隔离 防潮
122 封箱 防潮防尘
123 贴标识 物与卡相符
唛头
13 全尺寸、全性能检验 130 尺寸、性能 Z035936
8月12日更
前几天,由于忙没来的及更新,结论已经出来了,我把进展情况及更新如下
不良件的分析:(以下内容英文),我会有中文注(上传了金相图片不知道能不能看到大家)
(我同时也把图片及内容copy到word文档传了上来,)希望能能看到
最后这个供应商,成功被phase out,新开发的供应商已经成功供货将近2年,没有质量问题
新供应商是由我一手开发,该项目在该供应商的开发也是由我一手完成,有点小所成就感
该供应商的开发过程
1。potential 审核----对其整体的质量保证体系,审核后是YELLOW ,需要跟踪改进后才能引入
2。指导供应商针对potential 审核时的不符合项进行整改,提供了改进计划及各改进证据
3。验证整改效果。并重新审核
4。陪同老外的验收审核。global sourcing 总部派铸造审核专家直接过来验收审核(审核严苛之程度就不说了,是按照volvo 产品安全要求级别验收的,感觉陪同审核时心都是提到嗓子眼的,如果这次不过这家供应商就没机会了,得重新走其他的供应商选择流程。费时费力,关键是在老外面前丢人啊,中国供应商管理开发人员就是这水平吗?还好4天的审核下来,这老外(是个老头,审了一辈子供应商)还是比较满意
5。针对老外提出的改善点进行改善,并提交整改证据。
6。global souring 正式批准
7。该产品报价,产能评估云云--此处省略(采购同人来完成)
8。样件提交--含模具开发等
9。样件验证(可靠性试验,客户验证等)--结果ok
10。铸造过程开发
11。连续trial run1000件 发现砂眼不良率多
12。改进铸造工艺,主要是在模具上修改
13。重新trial run1000件,不良率合格
14。机加工过程开发
15。连续生产300件,收集数据计算过程能力,能力有点低,重新考虑加工工艺更改夹具
16。重新计算100件,过程能力可接受
15。准备PPAP资料
16。生产500件提交给我司进行组装trial run,无问题,并抽取5件成品发给客户验证
17。客户正式批准供应商变更
18。正式批准该供应商此产品的PSW
19。小批供货ramp up,5000件
20。系统释放大批订单。平稳供货
参与人数 4品质币 +79 收起 理由
wind_zhong878 + 28 很给力!
973643191 + 20
rqb163 + 1 很给力!期待后续。。。。。。。。.
icqwcy + 30 神马都是浮云
39
上海市
发表于 2021-3-12 13:48:09 | 显示全部楼层
不良件分析,很粗糙,最重要的内容,基本没有?
没有PFD、root cause......等等,购物、倒时差、解决问题的幸福感等等是“搞笑飞沫”
球化率、球化均匀性,珠光体、过热、过烧...
金相与断口分析...
0km失效数?
Tier被phase out这不是主要的
IATF五大手册/新产品项目启动&制造/CQI-n/SQM/VDA系列咨询培训。
顾问微信号:SGMChg
发表于 2021-3-11 20:48:42 | 显示全部楼层
发表于 2021-3-11 20:57:58 | 显示全部楼层
138
发表于 2021-3-11 21:46:35 | 显示全部楼层
6SQ论坛上转过来的
几年前就看过
临事静对猛虎,事了闲看落花
发表于 2021-3-11 21:49:04 | 显示全部楼层
发表于 2021-3-11 22:16:29 | 显示全部楼层
发表于 2021-3-12 00:27:46 | 显示全部楼层
发表于 2021-3-12 08:02:34 | 显示全部楼层
关注
发表于 2021-3-12 08:06:27 | 显示全部楼层
65
上海市
发表于 2021-3-12 08:15:27 | 显示全部楼层
GMT+8, 2024-5-6 06:06 , Processed in 0.040966 second(s), 7 queries , Gzip On, Redis On.
