查看: 7453|回复: 22
ISO 14097:2021《温室气体管理和相关活动》发布 Greenhouse gas
发表于 2021-6-23 20:55:37 | 显示全部楼层 |阅读模式
ISO 14097:2021 《Greenhouse gas management and related activities — Framework including principles and requirements for assessing and reporting investments and financing activities related to climate change 》(《温室气体管理和相关活动—包括评价和报告与气候变化有关的投资和融资活动的原则和要求的框架》) 发布,有助于融资方评价和报告其行动,并了解他们对气候目标贡献的真正价值。
ISO 14097:2021标准中概述的框架规定了所需的原则、要求和指南,这是建立在“变革理论”方法的基础上,目的是确定长期影响所需的条件。ISO 14097涵盖了投资决策对实体经济温室气体排放趋势的影响,投资和融资决策与低碳转型路径和气候目标的兼容性,以及气候目标或气候政策产生的金融资产所有者(如私人股本、上市股票、债券、贷款)。
制定ISO 14097:2021标准的ISO专家组的项目负责人 Massamba Thioye 表示 : “绿色金融投资既有助于全球减少温室气体排放所作的努力,也有助于金融资产本身的可持续性和长期盈利能力。金融家可以从碳密集型活动中撤资,以管理他们在气候相关风险中的风险敞口,但除非广泛开展,否则对温室气体排放的影响还很有限。更有效的做法是开展政策宣传,与被投资组织接触,利用其影响力促进其投资计划的绿化。因此,对他们来说,能够衡量这些行动对他们投资的组织的温室气体排放的影响至关重要。绿色金融成功的关键在于透明度和衡量,这也是本标准的目的所在。”
Thioye还是联合国气候变化框架公约秘书处减缓司的负责人,该秘书处是ISO的重要伙伴。
ISO 14097 是与气候变化和金融相关的新标准系列中的最新标准。其他正在制定的标准包括未来用于绿色债务工具环境绩效评价的ISO 14030系列标准、绿色金融项目评价的ISO 14100标准和 专注于为适应气候变化提供资金机制的ISO 14093标准。
This document specifies a general framework, including principles, requirements and guidance for assessing, measuring, monitoring and reporting on investments and financing activities in relation to climate change and the transition into a low-carbon economy. The assessment includes the following items:
—    the alignment (or lack thereof) of investment and financing decisions taken by the financier with low-carbon transition pathways, adaptation pathways, and climate goals;
—    the impact of actions through the financier’s investment and lending decisions towards the achievement of climate goals in the real economy, i.e. mitigation (greenhouse gas emissions) and adaptation (resilience);
—    the risks to owners of financial assets (e.g. private equities, listed stocks, bonds, loans) arising from climate change.
To support the financier’s assessment of the impact of investment and lending decisions, this document provides guidance for the financier on how to:
—    set targets and determine metrics to be used for tracking progress related to the low-carbon transition pathways of investees;
—    determine low-carbon transition and adaptation trajectories of investees;
—    document the causality or linkage between its climate action and its outputs, outcomes and impacts.
This document is applicable to financiers, i.e. investors and lenders. It guides their reporting activities to the following third parties: shareholders, clients, policymakers, financial supervisory authorities and non-governmental organizations.
文件规定了一个总体框架,包括评估、衡量、监测和报告与气候变化和向低碳经济转型有关的投融资活动的原则、要求和指南。评估包括以下项目:
— 金融家做出的投资和融资决策与低碳转型路径、适应路径和气候目标的一致性(或缺乏);
- 通过金融家的投资和贷款决策采取的行动对实体经济中实现气候目标的影响,即减缓(温室气体排放)和适应(恢复力);
— 气候变化对金融资产(如私募股权、上市股票、债券、贷款)所有者的风险。
为支持金融机构对投资和贷款决策影响的评估,本文件为金融机构提供了以下指导:
— 设定目标并确定用于跟踪被投资方低碳转型路径相关进展的指标;
——确定被投资方的低碳转型和适应轨迹;
— 记录其气候行动与其产出、结果和影响之间的因果关系或联系。
本文件适用于融资方,即投资者和贷方。它指导他们向以下第三方报告活动:股东、客户、政策制定者、金融监管机构和非政府组织。
上面右边中文部分直接是Google翻译的。
发表于 2021-6-24 06:53:27 | 显示全部楼层
非常感谢楼主分享
发表于 2021-6-24 07:52:57 | 显示全部楼层
感谢楼主分享
发表于 2021-6-24 08:00:39 | 显示全部楼层
感谢楼主分享
发表于 2021-6-24 08:02:00 | 显示全部楼层
发表于 2021-6-24 08:06:52 | 显示全部楼层
115
漂泊 尋根的迷途羔羊
顧問師
台湾 台中市
发表于 2021-6-24 08:09:22 | 显示全部楼层
感谢楼主無私分享
上班中;沒有不會做事的部屬 只有無能的主管。
微信號:hunter5168tw
65
上海市
发表于 2021-6-24 08:12:55 | 显示全部楼层
发表于 2021-6-24 08:33:57 | 显示全部楼层
广东省 东莞市 东莞市 樟木头镇
发表于 2021-6-24 08:42:38 | 显示全部楼层
GMT+8, 2024-5-8 13:12 , Processed in 0.039316 second(s), 5 queries , Gzip On, Redis On.
