查看: 8622|回复: 16
Hair Straighteners 直发棒证书有效期都将变为5年
发表于 2022-2-24 10:51:40 | 显示全部楼层 |阅读模式
认证检测
分类: 电子电气&数码家电(IT)
The extra requirements for hair straighteners have now been reMOVed by the regulators. This means that from now on, any hair straightener certificate will also be valid for 5 years and when we issue a renewal to an existing certificate, this will also be for 5 years.
监管部门取消了关于直发棒的额外要求。 从现在起,所有直发棒证书有效期都将变为5年。 同时原有证书更新, 新的证书有效期也是5年。
The extra requirements for hair straightener test reports requiring new testing have also been removed, so the requirements for the test report will be exactly the same as for all other products.
关于直发棒报告需要新的测试的要求也被取消, 所以直发棒的报告要求将和其他产品报告要求一样。
Existing certificates are not affected and this will only apply to new applications and renewals received from May 2021.
现有证书不会受此影响,此规定只适用于2021年5月起收到的新的证书申请和证书更新申请。
A reminder that any hair care product is a declared item and level 3 under the EESS/RCM classifications, so certification for these items, including hair straighteners, remains mandatory.
请注意,护发产品是强制性认证产品同时也是Level 3 产品,所以对此类产品, 包括直发棒,是强制性认证。
发表于 2022-2-24 13:02:53 | 显示全部楼层
21
发表于 2022-2-25 08:45:19 | 显示全部楼层
发表于 2022-2-27 11:07:23 | 显示全部楼层
发表于 2022-2-27 15:32:21 | 显示全部楼层
謝謝分享
发表于 2022-2-27 15:48:09 | 显示全部楼层
謝謝分享
发表于 2022-2-27 22:01:40 | 显示全部楼层
广东省 东莞市 东莞市 樟木头镇
发表于 2022-2-28 08:34:34 | 显示全部楼层
广东省 东莞市 东莞市 樟木头镇
发表于 2022-3-4 11:31:08 | 显示全部楼层
发表于 2022-3-4 11:34:26 | 显示全部楼层
GMT+8, 2024-5-10 02:09 , Processed in 0.030556 second(s), 6 queries , Gzip On, Redis On.
