查看: 7147|回复: 3
[以色列] 以色列发布用于可携式产品之镍电池及锂电池的强制性标准
发表于 2022-4-7 22:04:02 | 显示全部楼层 |阅读模式
以色列发布用于可携式产品之镍电池及锂电池的强制性标准SI 62133 Part 1和SI 62133 Part 2。
Safety requirements for portable sealed secondary cells and batteries of Nickel and Lithium systems will become mandatory from 2022/5/28.
SI 62133 Part 1 - Secondary cells and batteries containing alkaline or other non-acid electrolytes - Safety requirements for portable sealed secondary cells, and batteries made from them, for use in portable applications: Nickel systems
SI 62133 Part 2 - Secondary cells and batteries containing alkaline or other non-acid electrolytes - Safety requirements for portable sealed secondary cells, and batteries made from them, for use in portable applications: Lithium systems.
发表于 2022-4-20 09:36:45 | 显示全部楼层
发表于 2022-4-21 15:24:31 | 显示全部楼层
发表于 2022-4-22 17:08:48 | 显示全部楼层
GMT+8, 2024-5-4 02:51 , Processed in 0.023844 second(s), 5 queries , Gzip On, Redis On.
