查看: 7891|回复: 9
[墨西哥] 墨西哥发布照明标准 NMX-I-J-324-NYCE-ANCE-2022 的有效性声明
发表于 2022-4-7 22:10:46 | 显示全部楼层 |阅读模式
2022 年 3 月 17 日,墨西哥经济秘书处发布了关于照明标准 NMX-I-J-324-NYCE-ANCE-2022 的有效性声明,用于一般照明的集成发光二极管 (LED) 灯 - 安全要求和测试方法。
该标准规定了安全和可互换性要求、测试方法和条件,以表明集成 LED 灯的合规性,这些 LED 灯旨在用于住宅应用和类似的一般照明用途。
本标准将于 2022 年 9 月 13 日生效。
On 17 March 2022, the Mexican Secretariat of Economics published a Declaration of validity of Standard NMX-I-J-324-NYCE-ANCE-2022 on Lighting - Integrated Light Emitting Diode (LED) Lamps for General Lighting - Safety requirements and Test Methods.
The Standard establishes the safety and interchangeability requirements, test methods and conditions that are required to show compliance of integrated LED lamps, which are intended for residential applications and for similar general lighting purposes, with:
a) A nominal power of up to 150 W;
b) A nominal voltage greater than 50 V and up to 277 V; and
c) Caps according to Table 1.
The Standard is modelled on IEC 62560, except for the modifications set out in the table of this Declaration.
This Standard will enter into force on 13 September 2022 (180 calendar days after the publication of this Declaration of Validity in the Official Gazette).
发表于 2022-4-8 16:09:15 | 显示全部楼层
浙江省 杭州市 江干区 白杨街道
发表于 2022-4-10 08:06:30 | 显示全部楼层
广东省 东莞市 东莞市 樟木头镇
发表于 2022-4-11 08:41:16 | 显示全部楼层
发表于 2022-4-11 09:07:29 | 显示全部楼层
发表于 2022-4-11 14:35:16 | 显示全部楼层
謝謝分享
发表于 2022-4-16 19:53:34 | 显示全部楼层
发表于 2022-4-18 08:40:34 | 显示全部楼层
发表于 2022-4-21 15:18:46 | 显示全部楼层
发表于 2022-4-30 17:52:10 | 显示全部楼层
GMT+8, 2024-4-28 01:31 , Processed in 0.045146 second(s), 5 queries , Gzip On, Redis On.
