查看: 12356|回复: 4
[沙特] 沙特阿拉伯 Saudi Arabia 发布各行业相关的已采用标准清单
发表于 2022-4-7 22:15:40 | 显示全部楼层 |阅读模式
2022 年 3 月 11 日,沙特阿拉伯标准计量质量组织 (SASO) 发布了一份与各行业相关的已采用标准清单。该清单在SASO董事会183次会议上获得通过,标准主要来源于国际(ISOIEC和ASTM)标准。
在官方公报上发布 6 个月后,必须强制应用以下更新后的标准:
SASO 168:2022 使用液化石油气的家用炊具,
SASO 167:2022 使用液化石油气的家用炊具的测试方法,
SASO 2809:2014/Amd1:2022 底部装载油罐车 - 检查和定期维护。
除此之外,以下新的和更新的标准是自愿的:
SASO ASTM D3951:2022 商业包装标准实践,
SASO 2976:2022 食品包装用聚碳酸酯塑料容器,
SASO IEC 62977-2-1:2022 电子显示器 - 第 2 部分 - 1:光学特性的测量 - 基本测量,
SASO IEC 62977-2-2:2022 电子显示器 - 第 2 部分 - 2:光学特性的测量 - 环境性能,
SASO IEC 62052-11:2022 电力计量设备 - 一般要求、测试和测试条件 - 第 11 部分:计量设备,
SASO CISPR 14-1:2022 电磁兼容性 - 家用电器、电动工具和类似设备的要求 - 第 1 部分:发射,
SASO CISPR 14-2:2022 电磁兼容性 - 家用电器、电动工具和类似设备的要求 - 第 2 部分:抗扰度 - 产品系列标准,
SASO 2288:2014/Amd1:2022 道路车辆 - 底部装载油罐车和拖车。
On 11 March 2022, the Saudi Arabian Standards, Metrology and Quality Organisation (SASO) issued a list of adopted standards related to various sectors. The list was approved in the SASO board of directors’ meeting 183, and the standards are largely derived from international (ISO, IEC and ASTM) standards.
The application of the following updated standards, among others, is mandatory 6 months after publication in the official gazette:
SASO 168:2022 Domestic cookers for use with liquefied petroleum gases,
SASO 167:2022 Methods of test for domestic cookers for use with liquefied petroleum gases,
SASO 2809:2014/Amd1:2022 Bottom loading tank truck - inspection and periodic maintenance.
The following new and updated standards, among others, are voluntary:
SASO ASTM D3951:2022 Standard practice for commercial packaging,
SASO 2976:2022 Polycarbonate plastic containers for food packaging,
SASO IEC 62977-2-1:2022 Electronic displays - Part 2 - 1: Measurements of optical characteristics - Fundamental measurements,
SASO IEC 62977-2-2:2022 Electronic displays - Part 2 - 2: Measurements of optical characteristics - Ambient performance,
SASO IEC 62052-11:2022 Electricity metering equipment - General requirements, tests and test conditions - Part 11: Metering equipment,
SASO CISPR 14-1:2022 Electromagnetic compatibility - Requirements for household appliances, electric tools and similar apparatus - Part 1: Emission,
SASO CISPR 14-2:2022 Electromagnetic compatibility - Requirements for household appliances, electric tools and similar apparatus - Part 2: Immunity - Product family standard,
SASO 2288:2014/Amd1:2022 Road vehicles - Bottom loading tank truck and trailer.
广东省 东莞市 东莞市 樟木头镇
发表于 2022-4-8 08:31:22 | 显示全部楼层
发表于 2022-4-20 09:36:15 | 显示全部楼层
发表于 2022-4-28 13:16:01 | 显示全部楼层
发表于 2022-5-4 10:02:57 | 显示全部楼层
GMT+8, 2024-5-4 04:36 , Processed in 0.024341 second(s), 5 queries , Gzip On, Redis On.
