查看: 8042|回复: 15
[巴西] 巴西批准《用水设备质量和合格评定要求技术法规》
发表于 2022-5-7 11:20:55 | 显示全部楼层 |阅读模式
2022 年 3 月 25 日,巴西国家计量标准化和工业质量研究所 (INMETRO/CONMETRO) 发布第102号协议,批准了《用水设备质量和合格评定要求技术法规》。本协议于 2022 年 4 月 1 日生效。
On 25 March 2022, the Brazil National Institute of Metrology, Standardization and Industrial Quality (INMETRO/CONMETRO) published Portaria No. 102 to approve Technical Regulation on Quality and Conformity Assessment Requirements for Water Consumption Equipment.
The Regulation for Water Consumption Equipment was approved in the form of Technical Regulation on Quality, Conformity Assessment Requirements and Specifications for the Conformity Identification Mark, contained in Annexes I, II and III.
This Regulation applies to water consumption equipment of the following types, regardless of the technology applied:
electrical equipment with water cooling and without water quality improvement;
electrical appliances without water cooling and with water quality improvement;
electric equipment with water cooling and water quality improvement;
all non-electrical equipment that has the characteristic of improving the quality of water for human consumption.
The following products are excluded from the application of this Regulation:
equipment that supplies water without cooling and without performing water quality improvement;
filtering elements or water quality improvement devices, which are replacement components;
products intended to improve water quality through a suction process, such as squeeze bottles, straws, among others;
products intended for the treatment of non-potable water;
equipment for the production of ice;
coolers containing a container and/or hydraulic systems for supplying water and ice;
equipment exclusively intended to supply water for the production of tea, coffee, soups, juices and soft drinks.
The equipment is also under a non-automatic import licensing system, and the importer must obtain consent from Inmetro.
This Portaria entered into force on April 1, 2022.
浙江省
发表于 2022-5-8 08:07:42 | 显示全部楼层
发表于 2022-5-8 09:01:44 | 显示全部楼层
广东省 东莞市 东莞市 樟木头镇
发表于 2022-5-9 11:27:12 | 显示全部楼层
发表于 2022-5-14 13:54:33 | 显示全部楼层
发表于 2022-5-16 09:22:05 | 显示全部楼层
发表于 2022-5-16 21:02:19 | 显示全部楼层
发表于 2022-5-18 08:35:33 | 显示全部楼层
发表于 2022-5-19 09:00:47 | 显示全部楼层
发表于 2022-5-19 11:03:04 | 显示全部楼层
GMT+8, 2024-4-27 23:48 , Processed in 0.029238 second(s), 5 queries , Gzip On, Redis On.
