查看: 2466|回复: 17
欧亚经济联盟 EAEU 修订了《电磁兼容性技术法规》
发表于 2022-7-7 22:52:18 | 显示全部楼层 |阅读模式
2022 年 6 月 14 日,欧亚经济委员会发布了第 91 号决定,修订了《电磁兼容性技术法规》,包括并不限于以下变化:
增加了本技术法规不适用的技术方式
添加新定义
操作文件中的字母商标、专有名称、其他名称和细节可以用其他语言提供;
计量单位可以使用其国际名称给出;
如果信息量允许,则允许不起草操作文件,但在技术工具本身或其包装上标明信息;
将系统模块和收款机添加到需要以认证形式确认符合性的技术手段清单中;
将复印机 (包括多功能设备) 添加到需要以认证形式确认符合性的技术手段清单
该决定将于正式公布后 180 天后,即 2022 年 12 月 11 日生效。
https://docs.eaeunion.org/docs/r ... 14062022_91_doc.pdf
On 14 June 2022, the Eurasian Economic Commission published a Decision No. 91 amending Technical Regulations on Electromagnetic Compatibility.
The Decision introduced the following changes:
New edition of Article 2 adding technical means to which this technical regulation DOEs not apply: specially designed to ensure safety in the field of the use of atomic energy; used technical means (exploited); medical devices; defense products which ensure the interests of defense and security, including those supplied under the state defense order;
Adding new definitions;
Letter trademarks, proper names, names of settlements and other names and details in operational documents may be given in other languages;
Units of measurement may be given using their international designation;
If the amount of information provided for in paragraph 4 of the Article 5 allows, then it is allowed not to draw up operational documents, but to indicate the information on the technical tool itself or on its packaging;
Adding system blocks and cash registers, including those operating in conjunction with a computer to the list of technical means subject to confirmation of conformity in the form of certification (Annex 3, Part 3);
Adding copiers (including multifunction devices) to the list of technical means subject to confirmation of conformity in the form of certification (Annex 3, Part 4).
The Decision will enter into force 180 days after its official publication, on 11 December 2022.
发表于 2022-7-9 09:00:40 | 显示全部楼层
发表于 2022-7-9 14:51:27 | 显示全部楼层
发表于 2022-7-11 15:23:49 | 显示全部楼层
浙江省
发表于 2022-7-12 10:32:22 | 显示全部楼层
发表于 2022-7-13 09:42:53 | 显示全部楼层
感谢分享!
发表于 2022-7-13 11:59:11 | 显示全部楼层
謝謝分享
发表于 2022-7-13 12:08:49 | 显示全部楼层
謝謝分享
发表于 2022-7-14 08:14:59 | 显示全部楼层
发表于 2022-7-17 10:49:47 | 显示全部楼层
GMT+8, 2024-5-3 23:24 , Processed in 0.036382 second(s), 5 queries , Gzip On, Redis On.
