查看: 7899|回复: 28
[香港] 香港通讯事务管理局 (OFCA) 发布了新的类别牌照、HKCA1081标准
发表于 2022-7-7 22:53:20 | 显示全部楼层 |阅读模式
2022 年 4 月,中国香港通讯事务管理局 (OFCA) 发布了新的类别牌照、新的技术标准 HKCA1081 并更新了标签指引 HKCA3211。随着新法规的通过,通讯办现在允许 WLAN 设备部分使用 6 GHz 频谱。
In April 2022, the Office of the Communications Authority (OFCA) in Hong Kong published a new Class Licence, new Technical Standard HKCA1081 and update the labeling guideline HKCA3211.
With the adopted new regulations the OFCA allows now WLAN devices to utilize the 6 GHz spectrum partially:
“Client devices” are exempted from mandatory type approval processes, while “6 GHz Access Points” are expected to be subject to obligatory conformity assessment and labelling requirements.
Allowed Frequency band: 5.925 – 6.425 GHz
The maximum output power shall not exceed the limits indicated below:
Location of Use
Output Power (EIRP)
Indoor
24 dBm
Outdoor
14 dBm
All radiocommunications apparatus operating in the 6 GHz band shall meet the technical requirements in the ETSI EN 303 687 harmonised standard.
However, indoor devices are allowed to diverge from the mentioned EU requirements, namely:
- Power Output Limit has been increased to 24 dBm EIRP;
- PSD has been increased from 10 dBm/MHz to 11 dBm/MHz.
发表于 2022-7-8 09:48:10 | 显示全部楼层
发表于 2022-7-8 11:13:48 | 显示全部楼层
发表于 2022-7-8 14:52:52 | 显示全部楼层
发表于 2022-7-9 08:57:28 | 显示全部楼层
发表于 2022-7-9 10:16:51 | 显示全部楼层
感谢分享!
发表于 2022-7-9 12:38:11 | 显示全部楼层
发表于 2022-7-11 11:43:13 | 显示全部楼层
感谢分享!
发表于 2022-7-11 16:07:47 | 显示全部楼层
发表于 2022-7-12 08:14:03 | 显示全部楼层
感谢分享!
GMT+8, 2024-5-3 05:27 , Processed in 0.033742 second(s), 5 queries , Gzip On, Redis On.
