查看: 2707|回复: 18
今年TS22163体系会有升级吗?
发表于 2022-9-18 22:45:33 | 显示全部楼层 |阅读模式
如题,之前有听说要升级,但也不知道从哪儿去获得升级信息。今年TS22163体系会有升级(到DIS22163或者ISO22163)吗?
如果升级的话,作为企业半年后应该如何应审?文件是不是要更新啊?
79
 楼主| 发表于 2022-9-19 14:48:27 | 显示全部楼层
如果是2023年初进行正式发布的话,4月份左右审核的话也还是可以参照之前2017版标准的吧。
79
 楼主| 发表于 2022-9-19 14:44:21 | 显示全部楼层
从IRIS官网上看到的:https://www.iris-rail.org/index.php?page=global&content=global_information&desc=news#6216
Updatingthe IRIS Scheme – Status in September 2022
ISO/TC 269 Working Group 5 is working on an updatedISO/DIS 22163 to adapt and reach a worldwide consensus on the requirements.
The voting on the ISO/DIS 22163 ballot was closed this Maywith its principles approved. The ballot received a high number of commentsthat will now be discussed within the Working Group 5. IRIS ManagementCentre (IMC) foresees to have the document finalised in two months with anexpected publishing date in early 2023, following an FDIS ballot publication.
The DIS version of the document is currently available forpurchase on the ISO website, however, due to the high number of comments, thefinal version is expected to include several changes to the currently publishededition.
In case you have any questions about the progress on theISO 22163, please do not hesitate to contact the IMC.
Updatedversion of the IRIS Certification rules will be available in early 2023
Together with the standard, the International Rail QualityBoard’s (IRQB) Working Group 2.1 – led by the IMC – has started to updatethe IRIS Certification rules (currently referred to as the conformityassessment), aiming to include the updated ISO 22163 evolutions as well as tomake the rules easier to understand and thereby simplify the whole IRISCertification process.
The working group has proposed several changes to thecurrent rules, which were all validated by the IRQB Board. Others proposals andapplication details are still under discussion.
Full webAudit-Tool
Finally, the IMC is also working on updating the IRISAudit-Tool. This update will take all the above-mentioned evolutions intoaccount to enable a strong assessment tool for the auditors and an easypreparation tool for the companies.
Within the next months, the IMC will implement testversions to verify the reliability of the whole IRIS system.
IMC will keep you informed as these updates will befinalised and invites you to pass by the UNIFEStand 660 at Hub 27 at InnoTrans in Berlin for more details onlatest developments.
Make sure to also join the IRIS Certification sessions atInnoTrans. Held at the UNIFE stand, join us for a session on qualityperformance in the rail sector on 21September at 16.30 & on the evolutions of the IRIS scheme,held on 22 September at15.00.
79
 楼主| 发表于 2022-9-28 09:13:59 | 显示全部楼层
看了一份资料,里面提到了以下主要更改内容:
— business planning, innovation management and social responsibility moved to Clause 4 “Context
of the organization”;
— product safety requirements integrated in the quality requirements;
— revision of competence management;
— clarification of the RAMS/LCC requirements;
— creation of the notion of performance indicators (PI) versus KPI;
— revision of the mandatory PIs.
发表于 2022-9-19 07:07:58 | 显示全部楼层
交流探讨的帖子,在出现有效回答之前,不要发纯表情等无效回帖,无意义,太多了影响用户体验。经常这样账号会被扣分甚至禁号的。 ​  发表于 2022-9-19 08:01
参与人数 1品质币 -100 收起 理由
管理员 -100 第三次违规,下一次禁号。
发表于 2022-9-19 08:08:15 | 显示全部楼层
期待
发表于 2022-9-19 08:42:54 | 显示全部楼层
官网上搜一搜看看
发表于 2022-9-19 09:42:39 | 显示全部楼层
发表于 2022-9-19 09:51:08 | 显示全部楼层
发表于 2022-9-19 10:22:41 | 显示全部楼层
不知道,期待吧
79
 楼主| 发表于 2022-9-19 11:04:32 | 显示全部楼层
确实,本来我也觉得发些友善的表情没什么的。但如果一个话题抛出来,下面的都是纯表情,就感觉有点没意思。
可能也这是本论坛最大的一个问题,最好版主能适当管理导向一下。
GMT+8, 2024-5-2 09:53 , Processed in 0.033461 second(s), 6 queries , Gzip On, Redis On.
