查看: 2897|回复: 17
紧固件标准对照表: DIN德国标准、国际标准、中国标准
发表于 2022-9-27 23:59:53 | 显示全部楼层 |阅读模式
序号
Item
德国标准
DIN-Standard
中文品名
Description in Chinese
英文品名
Desciption in English
国际标准
ISO-Standard
中国标准
GB-Standard
1DIN1圆锥销Taper pinsISO2339GB117
2DIN7圆柱销Parallel pinsISO2339GB119-86
3DIN84开槽圆柱头螺钉Slotted cheese head screwsISO1207GB65-85
4DIN85开槽盘头螺钉Slotted pan head screwsISO1580GB67-85
5DIN93单耳止动垫圈Tab washers
GB854
6DIN94开口销Split cooter pinsISO1234GB91
7DIN95开槽半沉头木螺钉Slotted raised csk head wood screws
GB101
8DIN96开槽半圆头木螺钉Slotted round head wood screws
GB99
9DIN97开槽沉头木螺钉Slotted countersunk head wood screws
GB100
10DIN125-A平垫Plain washersISO7089GB97.1-85
11DIN125-B平垫(带倒角)Mediun washersISO7090GB97.2-85
12DIN126平垫Plain washersISO7091
13DIN127-A重型弹垫Spring lock washers,tang ends
GB7244
14DIN127-B标准弹垫Spring lock washers,square ends
GB93-87
15DIN128-A鞍形弹垫Single coil spring lock washers
GB7245-87
16DIN137-A弹簧止动垫圈Curved spring washers
17DIN137-B波形弹垫Wave spring washers
GB955
18DIN186T型方颈螺栓T-head blOTS with square neck
GB37-88
19DIN188T型双接头螺栓T-head bolts with double nip
20DIN258螺纹圆锥销Taper pins with threaded endISO8737
21DIN261T型头螺栓T-head bolts
22DIN315AF蝶型螺母(美制)Wing nutsAmericaform
23DIN315DF蝶型螺母(德制)Wing nuTSGermanyform
GB62-88
24DIN316AF蝶型螺母(美制)Wing screwsAmericaform
25DIN317DF蝶型螺母(德制)Wing screwsgermanyform
26DIN319圆球型盖型螺母Ball knobs
27DIN404开槽带孔球面
圆柱头蚴钉
Slotted capstan screws
GB832-88
28DIN417开槽长圆柱端
紧定螺钉
Slotted set srews with full dog pointISO7435GB75-85
29DIN427开槽平端
紧定螺钉(半牙)
Slotted set srews with chamfered endISO2342GB73-85
30DIN431小六角特薄细牙
螺母
Pip nuts with  thread
GB808-88
31DIN432外舌止动垫圈External tap
GB856-88
32DIN433小垫圈
(用于圆柱头螺钉)
Washers for  cheese head screwsISO7092GB848-95
33DIN434方斜垫圈(U型)Square taper  washers for
U-section
GB852-88
34DIN435方斜垫圈(I型)Square taper  washers for
I-sections
GB852-88
35DIN436方垫圈Square washers
36DIN438开槽凹端紧定螺钉Slotted set with  cup pointISO7436GB74-85
37DIN439六角薄螺母Hexagon thin  nutsISO4035GB6172-86
38DIN439细牙六角薄螺母Hexagon thin  nutsISO8675GB6173-86
39DIN440木螺钉专用垫圈Rounds washers  for wood constructionsISO7094
40DIN443密封帽Sealing  caps,push-in type
41DIN444活节螺栓B型Eye bolts form B
GB798-88
42DIN462内舌止动垫圈Internal tab  washers
43DIN463双耳止动垫圈Washers with two  taps
GB855-88
44DIN464滚花高头螺钉Knurled thumb  screws with collar
GB834-88
45DIN465开槽滚花高头螺钉Slotted knurled  thumb screws with collar
46DIN466滚花高螺母Knurled thumb  nuts with collar
GB806-88
47DIN467滚花薄螺母Knurled thumb  thin nuts
GB807-88
48DIN470锁紧垫圈Sealing washers
49DIN471轴用弹性垫圈Retaining rings  for shafts(external),circlips
GB893-86
50DIN472孔用弹性垫圈Retaining rings  for bores(internal),circlips
GB893.86
51DIN478方头带垫螺栓Square head  bolts with collar
52DIN479方头圆柱底端螺栓Square head  bolts with half dog point
53DIN480方头带垫关圆底端
螺栓
Square head  bolts with collar,half dog point
54DIN508T型槽螺母T-slot nutsISO299
55DIN525单头螺柱Single end studs
56DIN529地脚螺栓Masonry bolts
GB799-88
57DIN546带槽圆螺母Slotted round  nuts
GB817-76
58DIN547端面带孔圆螺母Round nuts with  drilled holes in one face
GB815-88
59DIN551开槽平端紧定螺钉Slotted set  screws with flat pointISO4776GB73-85
60DIN553开槽锥端紧定螺钉Slotted set  screws with cone pointISO7434GB71-85
61DIN555六角螺母Hexagon nutsISO4034
62DIN557方螺母-CSquare nuts
GB39-88
63DIN558六角头螺钉Hexagon screwsISO4018
64DIN561六角头圆柱端
紧定螺钉
Hexagon set  screws with full dog point
65DIN562薄型方螺母-BSquare nuts  without bevel
(pressed nuts)
66DIN571六角头木螺钉Hexgon head wood  screw
(coach screws)
GB102-86
67DIN580吊环螺钉Lifting eye  boltsISO3266GB825-76
68DIN582吊环螺母Lifting eye nuts
69DIN601六角头螺栓Hexagon blotsISO4016
70DIN603大半圆头方颈螺栓(马车螺栓)Mushroom head  square neck bolts(carriage bolts)ISO8677GB14-88
71DIN604沉头带插销马车
螺栓
Flat countersunk  nib bolts
72DIN605沉头长方颈马车
螺栓
Flat countersunk  long squareneck bolts
73DIN607半圆头带插销马车螺栓Cup head nib  bolts
74DIN608沉头短方颈马车
螺栓
Flat countersunk  short square neck bolts
75DIN609六角头精配螺栓
(长螺纹)
Hexagon fitted  bolts,long thread
76DIN610六角头精配螺栓
(短螺栓)
Hexagon fitted  bolts short thread
77DIN653滚花平头螺钉Knurled thumb  screws thin type
GB835-88
78DIN660半圆头铆钉Round head  rivetsISO1051GB867-86
79DIN661沉头铆钉Contersunk head  rivetsISO1051GB869-86
80DIN662半沉头铆钉Raised  contersunk head rivetsISO1051
81DIN674大扁头铆钉Mushroom head  rivetsISO1051
82DIN703重型侧面带孔圆螺母Adjusting  rings,heavy range(shafting collars)
83DIN705侧面带孔圆螺母Adjusting  rings,light range(shafting collars)
GB816-88
84DIN741卡头Wire rope clips
85DIN787T型槽螺钉T-slot screwsISO299
86DIN835双头螺柱
(牙长=2D)
Studs-metal(end=2d)
GB900-88
87DIN906内六角锥型闭锁
螺钉
Hexagon socket  pipe plugs,conical thread
88DIN908内六角直型闭锁
螺钉
Thread
89DIN909外六角锥型闭锁
螺钉
Thread
90DIN910外六角直型闭锁
螺钉
Hexagon head  screw plugs,cyl.thread
91DIN911内六角扳手Socket wrenchesISO2936
92DIN912内六角圆柱头螺钉Hexagon socket  cap screwsISO4762GB70-85
93DIN913内六角平端紧定
螺钉
Hexagon socket  set screws with falt pointISO4026GB77-85
94DIN914内六角尖端紧定
螺钉
Hexagon socket  set screws with cone pointISO4027GB78-85
95DIN915内六角圆柱端紧定螺钉Hexagon socket  set screws with dog pointISO4028GB79-85
96DIN916内六角凹端紧定螺钉Hexagon socket  set screws with cup pointISO4029GB80-85
97DIN917薄型盲螺母Hexagon cap nuts
98DIN920开槽小圆柱头螺钉Slotted short  cheese head screws
99DIN921开槽大圆柱头螺钉Slotted large  cheese head screws
GB838-88
100DIN923开槽圆柱头轴肩
螺钉
Slotted pan head  screw with shoulder
GB830-88
101DIN927开槽无头轴肩螺钉Slotted shoulder  screws
102DIN928焊接方螺母Square weld nuts
GB/T13680-92
103DIN929焊接六角螺母Hexagon weld  nuts
GB/T13681-92
104DIN931六角头螺栓
(全牙)
Hexagon head  screwsISO4014GB5782-86
105DIN933六角头螺栓
(半牙)
Hexagon head  screwsISO4017GB5783-86
106DIN934六角头螺母(1型)Hexagon full  nutsISO4032GB6170-86
107DIN934细牙六角头螺母(1型)Hexagon full  nutsISO8673GB6171-86
108DIN935开槽六角螺母Hexagon slotted  and castle nutsISO7035GB6178-86
109DIN936六角头薄螺母Hexagon thin  nutsISO4035GB6172.1-86
110DIN937六角头开槽薄螺母Hexagon thin  slotted and caslte nutsISO7038GB6181-86
111DIN938双头螺距
(牙长=1D)
Studs  metal(end=1d)
GB897-88
112DIN939双头螺距
(牙长=1.5D)
Studs  metal(end=1.25d)
GB898-88
113DIN940双头螺距
(牙长=1.25D)
Studs  metal(end=1.5d)
114DIN960六角头细牙螺栓
(全牙)
Hexagon head  bolts,metric fine pitch threadISO8765GB5785-86
115DIN961六角头细牙螺栓
(半牙)
Hexagon head  bolts,metric fine pitch threadISO8676GB8786-86
116DIN962头部穿孔六角头
螺栓
Additional shapes  and versions for bolts
117DIN963开槽沉头螺钉Slotted  countersund head screwsISO2009GB68-85
118DIN964开槽半沉头螺钉Slotted raised  countersunk oval head screwsISO2010GB69-85
119DIN965十字槽沉头螺钉Cross recessed  countersunk head screwsISO7046GB819-85
120DIN966十字槽半沉头螺钉Cross recessed  raisedCountersunk head  screwsISO7047GB820-85
121DIN970六角头螺母Hexagon nuts  type-1
122DIN971六角头螺母Hexagon nuts  type-2
123DIN972细牙六角头螺母(2型)Hexagon nuts  with fine thread
124DIN975牙条(全螺纹)Threaded rods(studdings)ISO8674GB6176-86
125DIN976螺纹销Threaded  pins(stud bolts)
GB15389-94
126DIN979六角头开槽薄螺母(2型)Hexagon thin  slotted and castle nuts
127DIN980全金属六角锁紧螺母(1型)Prevaillng  rorque type hexagon nuts,all metal nuts
128DIN981圆螺母LocknutsISO7199GB6184-86
129DIN982六角头尼龙锁紧螺母Prevailing  rorque type hexagon nuts,heavy type,with nylonISO2982GB812-88
130DIN985六角头薄型尼龙锁紧螺母Prevalling  torque type hoxagon nuts,heavy type,with nylonISO7040GB889.1-86
131DIN986六角盖型尼龙锁紧螺母Preailling  torque typedomed capnuts with nylon insertISO10511GB6172.2-86
132DIN988配合垫片Shim rings
133DIN1052木材连接用垫片Washers for  timber connectors
134DIN1151沉头钢钉Round plain head  nails
135DIN1440销钉专用垫片A型Plain washers  for clevis pins(A型)ISO8738
136DIN1441销钉专用垫片Plain washers  for clevis pins
137DIN1444带头销钉Clevis pins with  headISO2341
138DIN1471圆锥型槽销Grooved  pins,taper groovedISO8744GB/T13829.2
139DIN1472圆锥型槽销
(半槽)
Grooved  pins,taper grooved half lengthISO8745GB/T13829.2
140DIN1473平行槽销
(带倒角)
Grooved  pins,parallel grooved full lengthISO8740
141DIN1474前端凹槽槽销Grooved  pins,reverve grooved half lengthISO8741
142DIN1475中部凹槽槽销Grooved  pins,center groovedISO8742
143DIN1476圆头槽销Grooved pins  with round headISO8746
144DIN1477沉头槽销Grooved pins  with countersunk headISO8747
145DIN1479六角螺母棒Turnuckles(center  parts),made out of hexagon bar
146DIN1480花蓝螺栓Turnuckles with  eye bolt and hook bolt
147DIN1481弹性圆柱销Spring  pins,heavy typeISO8752GB879-86
148DIN1587组合式盖型螺母Hexagon domed  cap nuts
GB802-88
149DIN1804开槽圆螺母
(配合沟头扳手)
Slotted round  nuts for hook spammer
150DIN1816圆螺母(带插销孔)Round nuts with  set holes
151DIN2093盘型弹簧垫圈Disc springs
152DIN3017喉箍Hose clamps
153DIN3404润滑油嘴
(旋扭头)
Lubricating  nipples,button head
154DIN3567管夹Shackles for  conduilts
155DIN3570U型螺栓Stirrup  bolts(U-bolts)
156DIN6319球面垫圈Spherical  washers,conical seats
GB849-88
157DIN6325圆柱销Parallel pinsISO8734
158DIN6330厚六角螺母Hexagon  nuts,1.5d
GB56-88
159DIN6331厚六角法兰面
螺母
Hexagon  nuts,1.5d with collar
GB6177-86
160DIN6334长六角螺母Hexagon nuts,3d
161DIN6797-A外齿锁紧垫圈External teeth  lock washers
GB862.1-87
162DIN6797-I内齿锁紧垫圈Internal teeth  lock washers
GB861.1-87
163DIN6798-A外锯齿锁紧垫圈External teeth  serrated lock washers
GB862.2-87
164DIN6798-I内锯齿锁紧垫圈Internal teeth  serrated lock washers
GB861.2-87
165DIN6799开口挡圈Retaining rings  for shafts(E-rings),circlips
GB896-76
166DIN6885平键(A型)Parallel  keys(form A)ISO773/2491
167DIN6888半圆键Woodruff keysISO3912
168DIN6899嵌环(支撑环)Thimbles
169DIN6900机器螺钉和垫圈
组合件
Screws and  washers assemblies
170DIN6901自攻螺钉和垫圈
组合件
Tapping screws  and washer assemblies
GB9074.1-17
171DIN6912薄型带孔
内六角圆柱螺钉
Hexagon cocket  head cap screws with hole,low head
GB9074.18-23
172DIN6914大六角头螺栓Hexagon head  bolts with large head
(friction grip nolts)
173DIN6915大六角螺母Hexagon nuts  with large wideth across flat
(friction grip nuts)
174DIN6916大垫圈Round washers  for friction grip bolts
175DIN6917楔型方垫圈Spuare taper  washers for friction grip bolts on T-
176DIN6923六角法兰面螺母Hexagon flange  nutsISO4161GB6187-86
177DIN6925全金属六角锁紧螺母(2型)Prevailing  torque type hexagon nuts,all metallic nutsISO7042GB6185.1-2000
181DIN7346轻型弹性圆柱销Spring  pins,light typeISO13337
182DIN7349重型弹性圆柱
销用垫圈
Washers for  bolts with heavy type spring pinss
183DIN7500ISO公制螺纹螺钉(多种头型)Thread forming  screws for ISO-metric thread
184DIN7504自攻自钻螺钉
(多种头型)
Self-drilling  tapping screws
185DIN7513开槽切削螺纹螺钉(多种头型)Thread cutting  screws
186DIN7516十字槽切削螺纹螺钉(多种头型)Thread cutting  screws cross recess
187DIN7965T型四爪螺母Tee nuts with  pronge
188DIN7968钢结构用六角头螺栓连接副Hexagon head  fitted bolts for steel structures
GB1228/1229/1230
189DIN7971开槽盘头
自攻螺钉
Pan head tapping  screws with slotISO1481GB5282-85
190DIN7972开槽沉头
自攻螺钉
countersunk flat  head tapping screws with slotISO1482GB5283-85
191DIN7973开槽半沉头
自攻螺钉
Raised  sountersunk oval head tapping screws with slotISO1483GB5284-85
192DIN7976六角头自攻螺钉Hexagon tapping  screwsISO1479GB5285-85
193DIN7980圆柱头螺钉用
弹簧垫圈
Spring lock  washers for screws with cylindrical headsISO8738
194DIN7981十字槽盘头
自攻螺攻
Pan head tapping  screws with cross recessedISO7049GB845-85
195DIN7982十字槽沉头
自攻螺攻
Countersunk flat  head tapping screws with cross recessedISO7050GB846-85
196DIN7983十字槽半沉头
自攻螺攻
Raised  countersunk oval head tapping screws with crossISO7051GB847-86
197DIN7984薄型内六角
圆柱头螺钉
Hexagon socket  head cap screws with,reduced head
198DIN7985十字槽盘头螺钉Pan head screws  with cross recessedISO7045GB818-85
199DIN7989钢结构用垫圈Washers for  steel structures
GB1230-84
200DIN7990钢结构用
六角头螺栓
Hexagon head  bolts for steel structures
GB1229-84
201DIN7991内六角沉头螺钉Hexagon socket  coutersunk head screwsISO10642
202DIN7993轴用钢丝挡圈Roundwire snap  rings for shafts
GB895.2-86
203DIN7995十字槽半沉头
木螺钉
Cross recessed  raised countersunk head wood screws
GB952-86
204DIN7996十字槽圆头
木螺钉
Cross recessed  round head wood screws
GB950-86
205DIN7997十字槽沉头
木螺钉
Cross recessed  countersunk head wood screws
GB951-86
206DIN8140螺纹护套
(普通、自锁等)
Ciol  inserts,coarse,fine thread,silf locking
207DIN9021大外径垫圈Washers,outside  diameter appro.3dISO7093GB96-85
208DIN11024弹簧卡子sping cotter for  a bolt
209DIN13257平板螺栓Belting bolts
(elevator bolts)
210DIN18182干壁钉
(墙板钉)
Dry wall screws
211DIN28129环型螺母Lifting nuts(eye  nuts)
GB63-88
212DIN70952圆螺母用止退
垫圈
Tab washer for  slotted round nuts
GB/858-88
山东省 济宁市 任城区
发表于 2022-9-28 07:15:04 | 显示全部楼层
发表于 2022-9-28 07:20:36 | 显示全部楼层
发表于 2022-9-28 08:16:34 | 显示全部楼层
发表于 2022-9-28 08:22:59 | 显示全部楼层
厉害
发表于 2022-9-28 08:23:45 | 显示全部楼层
发表于 2022-9-28 08:38:35 | 显示全部楼层
发表于 2022-9-28 08:56:34 | 显示全部楼层
发表于 2022-9-28 08:58:57 | 显示全部楼层
发表于 2022-9-28 09:03:34 | 显示全部楼层
GMT+8, 2024-5-11 21:20 , Processed in 0.072517 second(s), 5 queries , Gzip On, Redis On.
