查看: 5641|回复: 8
Appliance Connector 电器连接器 AS/NZS 60320.1, AS/NZS 60320.2.2, IEC 603...
发表于 2023-1-11 18:25:54 | 显示全部楼层 |阅读模式
认证检测
分类: 电子电气&数码家电(IT)
An electrical device which —
(a) is for attachment to a flexible cord; and
(b) makes a detachable connection between the conductors of the cord and the pins or contacts of any low voltage appliance or equipment of a type intended or generally used for household applications;
But DOEs not include —
(c) a connector within the scope of AS/NZS 3123; or
(d) a plug or socket-outlet within the scope of AS/NZS 3131; or
(e) an installation coupler within the scope of AS/NZS 61535.1.
Class Specification:
Appliance connector:AS/NZS 60320.1
Plug connector:AS/NZS 60320.1 and AS/NZS 60320.2.2
Sewing machine connector:AS/NZS 60320.1
Standard Sheets as appropriate:IEC 60320-1, 60320-2-2 or 60320-3
一种电气设备,符合以下条件:
(a) 用于连接到软线;
(b) 在电源线的导体与任何用于或通常用于家庭应用的类型的低压电器或设备的引脚或触点之间建立可拆卸的连接;
但不包括 —
(c) AS/NZS 3123 范围内的连接器;或
(d) AS/NZS 3131 范围内的插头或插座;或
(e) AS/NZS 61535.1 范围内的安装耦合器。
类规范:
设备连接器:AS/NZS 60320.1
插头连接器:AS/NZS 60320.1 和 AS/NZS 60320.2.2
缝纫机连接器:AS/NZS 60320.1
标准表(视情况而定):IEC 60320-1、60320-2-2 或 60320-3
发表于 2023-1-14 14:44:19 | 显示全部楼层
发表于 2023-1-14 14:50:18 | 显示全部楼层
发表于 2023-1-15 23:57:54 | 显示全部楼层
发表于 2023-1-16 00:03:08 | 显示全部楼层
发表于 2023-1-16 08:48:57 | 显示全部楼层
发表于 2023-1-22 08:09:23 | 显示全部楼层
发表于 2023-1-29 08:36:29 | 显示全部楼层
发表于 2023-12-11 20:26:33 | 显示全部楼层
GMT+8, 2024-5-6 18:49 , Processed in 0.032472 second(s), 6 queries , Gzip On, Redis On.
