查看: 4956|回复: 22
VDA Field Failure Analysis & Audit Standard
发表于 2023-2-4 14:19:11 | 显示全部楼层 |阅读模式
Preface
Following the first edition of the VDA “Field Failure Analysis” publication in 2009 and the audit standard in 2011, both publications were fundamentally revised and consolidated.
The second edition is an update and an optimised version which incorporates the accumulated experience.
In addition, the VDA “Field Failure Analysis” publication also contains the following key aspects:
  • Greater focus on the entire supply chain
  • Stronger integration of the planning process into the product development process
  • Improved analysis of customer complaints and data management
  • Consideration of multiple failures
  • Example of NTF guidelines included
  • Problem analysis with special cases
  • Expanded problem-solving process
  • Market monitoring integrated
  • Audit questionnaire expanded and restructured
English language version.
VDA Field Failure Analysis & Audit Standard.pdf
859.04 KB, 下载次数: 133
40
 楼主| 发表于 2023-2-4 14:19:27 | 显示全部楼层
发表于 2023-2-4 14:51:50 | 显示全部楼层
24
VIP会员
Rank: 6Rank: 6
发表于 2023-2-4 15:36:03 | 显示全部楼层
发表于 2023-2-4 19:41:26 | 显示全部楼层
发表于 2023-2-4 20:13:47 | 显示全部楼层
发表于 2023-2-4 22:00:30 | 显示全部楼层
谢谢分享, 另请问有最新版本的吗?
发表于 2023-2-5 08:03:47 | 显示全部楼层
发表于 2023-2-5 08:45:24 | 显示全部楼层
发表于 2023-2-5 08:48:13 | 显示全部楼层
GMT+8, 2024-5-2 15:56 , Processed in 0.037477 second(s), 6 queries , Gzip On, Redis On.
