查看: 1229|回复: 17
求个题不会做了
发表于 2023-10-25 21:16:11 | 显示全部楼层 |阅读模式
A control chart for defects per unit uses probability limits corresponding to probabilities of 0.975 and 0.025. The central line on the control chart is at 2.0. The limits vary with the value of n. Determine the correct position of these upper and lower control limits when n=5:
a. 3.24, 0.76
b. 2.32, 0.96
c. 4.23, 0.67
d. 3.73, 0.49
发表于 2023-10-26 08:48:59 | 显示全部楼层
The control limits for a defects per unit chart with n=5 and central line at 2.0 using probabilities of 0.975 and 0.025 can be calculated as follows:
Upper Control Limit (UCL) = CL + A2 * sqrt(CL/n)
Lower Control Limit (LCL) = CL - A2 * sqrt(CL/n)
where CL is the central line, A2 is the control chart factor for n=5 and probabilities of 0.975 and 0.025, and sqrt is the square root function.
From statistical tables, we can find that A2=0.577 for n=5 and probabilities of 0.975 and 0.025.
Substituting the values into the formulas, we get:
UCL = 2.0 + 0.577 * sqrt(2.0/5) ≈ 3.24
LCL = 2.0 - 0.577 * sqrt(2.0/5) ≈ 0.76
Therefore, the correct position of the upper and lower control limits when n=5 is option a. 3.24, 0.76.
混子
山东省 青岛市 李沧区 虎山路街道
发表于 2023-10-26 08:28:38 | 显示全部楼层
我不仅不会,题都看不懂
发表于 2023-10-26 08:31:22 | 显示全部楼层
孔子看不懂,孟子看不懂,老子也看不懂。
发表于 2023-10-26 09:33:55 | 显示全部楼层
排除法,以2为中心±3s,bcd都不对称
107
发表于 2023-10-26 09:35:23 | 显示全部楼层
njkiller 发表于 2023-10-26 08:48
The control limits for a defects per unit chart with n=5 and central line at 2.0 using probabilities ...
厉害
发表于 2023-10-26 09:39:48 | 显示全部楼层
中心线2.0  除了A,其它都不符合吧
发表于 2023-10-26 09:50:25 | 显示全部楼层
所有单词似乎都认识,放在一起那阿拉伯数字绝对没跑了
发表于 2023-10-26 11:00:15 | 显示全部楼层
132
发表于 2023-10-26 11:12:33 | 显示全部楼层
非常喜欢这个 ...
GMT+8, 2024-4-27 13:58 , Processed in 0.062998 second(s), 7 queries , Gzip On, Redis On.
