查看: 1328|回复: 26
次级供应商汽车行业质量管理体系最低要求
发表于 2024-2-3 10:16:48 | 显示全部楼层 |阅读模式
© AIAG, © ANFIA, © FIEV, © SMMT, © VDA -2016-版权所有 Minimum-Automotive-Quality-Management-System-Requirements-for-Sub-tier-supplier
汽车QMS要求目录
1 控制计划 ................................................................................................................................................... 2
2 过程方法 ................................................................................................................................................... 2
3 绩效 ........................................................................................................................................................... 2
4 内部审核 ................................................................................................................................................... 3
5 不合格品控制 ............................................................................................................................................ 3
6 零件批准 ................................................................................................................................................... 3
7 管理责任 ................................................................................................................................................... 4
8 风险管理 ................................................................................................................................................... 4
9 安全 ........................................................................................................................................................... 4
附件 .............................................................................................................................................................. 4
Minimum-Automotive-Quality-Management-System-Requirements-for-Sub-tier-supplier.pdf
354.24 KB, 下载次数: 117
 楼主| 发表于 2024-2-3 10:17:07 | 显示全部楼层
发表于 2024-2-3 13:34:47 | 显示全部楼层
发表于 2024-2-3 13:37:16 | 显示全部楼层
发表于 2024-2-3 15:23:34 | 显示全部楼层
发表于 2024-2-3 15:34:29 | 显示全部楼层
发表于 2024-2-3 18:01:53 | 显示全部楼层
发表于 2024-2-3 23:07:38 | 显示全部楼层
发表于 2024-2-4 06:41:47 | 显示全部楼层
发表于 2024-2-4 07:07:44 | 显示全部楼层
GMT+8, 2024-5-8 09:27 , Processed in 0.063092 second(s), 8 queries , Gzip On, Redis On.
