Stat > DOE > Factorial > Analyze Factorial Design > Weights
You can specify weights for your model to perform weighted regression, which is a method to handle data with observations that have different variances. Store weights based on the variability in your response across repeats or replicates in Analyze Variability.
You cannot specify weights for split-plot designs. |
Do a weighted fit, using weights in: Enter a column that contains weights for your response. The column must be the same length as the design variables.
