You are an engineer investigating how processing conditions affect the
yield of a chemical reaction. You believe that three processing conditions,
or factors
1 Open the worksheet YIELD.MTW. (The design and response data have been saved for you.)
2 Choose Stat > DOE > Factorial > Analyze Factorial Design.
3 In Responses, enter Yield.
4 Click Graphs. Under Effects Plots, check Pareto, Normal, and Half Normal.
5 Click OK in each dialog box.
Session window output
Graph window output Interpreting the resultsThe analysis of variance table gives a summary of the main effects and interactions. Minitab displays both the sequential sums of squares (Seq SS) and adjusted sums of squares (Adj SS). If the model is orthogonal and does not contain covariates, these will be the same. See Adjusted versus Sequential Sums of Squares for a description of when the values are different. Look at the p-values to determine whether you have any significant effects. The nonsignificant block effect indicates that the data do not show a statistically significant difference between the data from the two different days. The p-values for the main (linear) effects (0.000) and two-way interactions (0.017) are significant at alpha = 0.05 significance level. The analysis of variance table and the estimated effects and coefficients table show the p-values for each individual model term. The p-values indicate that only one two-way interaction, Time * Temp (p = 0.003), and two main (linear) effects, Time (p = 0.000) and Temp (p = 0.000), are significant. See Example of factorial plots for an experiment with three factors for a discussion of this interaction. The residual error that is shown in the ANOVA table can be made up of three parts: (1) curvature, if there are center points in the data, (2) lack of fit, if a reduced model was fit, and (3) pure error, if there are any replicates. If the residual error is due only to lack of fit, Minitab does not print this breakdown. In all other cases, it does. The normal, half normal, and Pareto plots of the effects allow you to visually identify the important effects and compare the relative magnitude of the various effects. You should also plot the residuals versus the run order to check for any time trends or other nonrandom patterns. Residual plots are in the Graphs subdialog box. See Residual plots choices.
