Example of preprocessing responses for analyze variability
    interpreting results     session command     see also
You are investigating how processing conditions affect the yield of a chemical reaction. You believe that three processing conditions (factors)-reaction time, reaction temperature, and type of catalyst-affect the variability in yield. You decide to conduct a 2-level full factorial experiment with 8 replicates so you can analyze the variability in the responses at different factor settings.
In order to analyze the variability in your responses, you must first preprocess the replicate responses to calculate and store the standard deviations and number of replicates.
1    Open the worksheet YIELDSTDEV.MTW. (The design and response data have been saved for you.)
2    Choose Stat > DOE > Factorial > Preprocess Responses for Analyze Variability.
3    Under Standard deviations to use for analysis, choose Compute for repeat responses across rows.
3    In Repeat responses across rows of, enter 'Yield_1'-'Yield_8'.
4    In Store standard deviations in, enter StdYield to name the column in which the standard deviations are stored.
5    In Store number of repeats in, enter NYield to name the column in which the number of repeats are stored. Click OK.
Data window output
Note
Preprocessing responses does not produce output in the Session window. Instead, columns are stored in the worksheet.
StdOrder
RunOrder
CenterPt
Blocks
Time
Temp
Catalyst
Yield_1
Yield_2
Yield_3
Yield_4
Yield_5
Yield_6
Yield_7
Yield_8
StdYield
NYield
A
45.1931
48.4485
47.3932
42.1684
45.4934
42.9325
45.9203
43.2976
0.2800
150
A
59.6118
49.7662
43.5734
41.8365
45.7207
49.7236
47.3297
55.2384
3.0456
A
44.8025
48.3112
43.3937
51.2708
43.1891
46.3449
43.3953
49.1860
1.0240
200
A
43.2365
46.2602
59.7650
38.0484
42.7636
39.8702
59.4553
48.5013
8.0317
B
38.8697
56.4470
48.4665
41.6720
42.2025
44.7592
49.2040
49.1959
0.4915
150
B
47.2578
39.9795
44.7077
43.2094
60.0008
43.0617
43.6365
53.0645
3.9723
B
42.3529
42.1531
42.9112
43.1371
43.8015
45.5991
43.2711
43.0210
2.0003
200
B
40.7675
45.8798
40.4579
42.3855
43.3958
44.0803
40.3418
44.8547
10.0303
Interpreting the results
In the example, Minitab calculates and stores the standard deviations of the repeats of yield in the column StdYield. Minitab calculates and stores the number of repeats in the column NYield. Minitab stores one standard deviation and the number of repeats for each combination of factor settings in the row where that combination first appears. In this example, Minitab stored 8 standard deviations and 8 numbers of repeats, filling the remaining rows with the missing data symbol (*).
To analyze this data using Analyze Variability, see Example of analyzing variability. Keep this worksheet active in order to use the stored standard deviations and number of repeats in the analyzing variability example.
Note
If this data contained replicates instead of repeats, the worksheet will look different than the worksheet above, but the results produced by analyzing the variability in the data will be the same.
