When you have repeat measurements of your response, Minitab calculates the mean of the repeats for each row and stores them in a column. You can then analyze these stored means in Analyze Factorial Design. If you have repeats with some replicated points, you can use the row means to store adjusted weights when you analyze variability of the repeats.
