Stat > DOE > Mixture > Create Mixture Design > choose Simplex centroid > Designs
Generates settings for the components in an experiment with a simplex centroid design. You can
Augment the design with axial points: Check to augment (or adds points to) the base design. See Placement of axial points in augmented designs.
Replicate Design Points
Number of replicates for the whole design: Choose to replicate the whole design, then choose a number of to 50 for the number of replicates.
Number of replicates for the selected types of points: Choose to replicate only certain types of design points from the base design. Then, under Number, enter the number of replicates for each point type.
