Stat > DOE > Mixture > Create Mixture Design > choose Simplex lattice > Designs
Generates settings for the components in an experiment with a simplex lattice design. You can
Degree of lattice: Choose a degree for your design from the drop-down list. The choices available depend on the number of components you chose in the main Create Mixture Design dialog box.
Augment the design with center points: Check to add a center point to the design.
Augment the design with axial points: Check to add axial points to design. See Placement of axial points in augmented designs.
Replicate Design Points:
Number of replicates for the whole design: Choose to replicate the whole design, then choose a number of to 50 for the number of replicates.
Number of replicates for the selected types of points: Choose to replicate only certain types of design points from the base design. Then, under Number, enter the number of replicates for each point type.
