1 In the Create Mixture Design dialog box, click Process Vars.
2 Under Name, click in the first row and type the name of the first process variable. Then, use the arrow key to move down the column and enter the remaining names.
3 Click OK.
More |
After you have created the design, you can change the process variable names by typing new names in the Data window, or with Modify Design. |
