Stat > DOE > Mixture > Define Custom Mixture Design > Lower/Upper > Linear constraints
Allows you to set linear constraints for the set of components. See Setting linear constraints for extreme vertices designs for details.
Specify a coefficient for one or more components, and a value for Lower and/or Upper
Lower: Enter the lower value for the linear constraint.
A,
B, C,
Upper: Enter the upper value for the linear constraint.
