In the Example of a simple histogram, you determine the amount of torque required to remove shampoo bottle caps. You want to fit a lowess smoother to the data.
Lowess smoother 1 Open the worksheet CAP.MTW. 2 Choose Graph > Histogram. 3 Choose Simple, then click OK. 4 In Graph variables, enter Torque. 5 Click Scale. 6 Under Y Scale Low and X Scale Low, check Minor ticks. Click OK. 7 Click Data View. 8 Click the Smoother tab. 9 Under Smoother, choose Lowess. 10 Click OK in each dialog box. |
