Boxplot - Data View - Data Display
overview
     how to      examples
... > Data View > Data Display
Graphs that allow this function
Use to represent the data with one or more data display types, including boxes, symbols, and connect lines. After creating a graph, you can:
·    Change the data display attributes (see Editing Data Display Overview).
·    Add or remove data display types (see Adding Graph Elements).
Data Display
Median confidence interval box: Check to display a confidence interval box, which shows the 95% (default) confidence interval for the median.
Interquartile range box: Check to display an interquartile range box (default). The box bottom is at the 25th percentile and box top at the 75th percentile.
Range box: Check to display a box that extends from the minimum data value to the maximum data value.
Outlier symbols: Check to represent each outlier with a symbol.
Individual symbols: Check to represent each data point with a symbol.
Median symbol: Check to represent each median with a symbol.
Median connect line: Check to connect the medians of boxplots (only visible if you have categorical variables in the boxplot).
Mean symbol: Check to represent each mean with a symbol.
Mean connect line: Check to connect the means of grouped plots (only visible if you have categorical variables in the boxplot).
Categorical variables for attribute assignment: (Only available if a With Groups option was selected from the boxplot gallery.) Enter up to four columns of grouping variables to assign different attributes to each group of the categorical x-scale variables. You can only use categorical variables included in the boxplot.
Calendar with week numbers
US Federal Holidays
Australia Public Holidays
