To change the data display
examples
1    In the graph dialog box, click Data View.
2    Under Data Display, check one or more of the following:
·    Median confidence interval box to display a confidence interval box, which shows the 95% (default) confidence interval for the median.
·    Interquartile range box to display an interquartile range box (default), with the box bottom at the 25th percentile and box top at the 75th percentile.
·    Range box to display a box that extends from the minimum data value to the maximum data value.
·    Outlier symbols to represent each outlier with a symbol.
·    Individual symbols to represent each data point with a symbol.
·    Median symbol to represent each median with a symbol.
·    Median connect line to connect the medians of grouped plots (only visible if you have categorical variables in the boxplot).
·    Mean symbol to represent each mean with a symbol.
·    Mean connect line to connect the means of grouped plots (only visible if you have categorical variables in the boxplot).
3    (Only available if a With Groups option was selected from the boxplot gallery.) In Categorical variables for attribute assignment, enter up to four columns of grouping variables to assign different attributes to each group of the categorical x-scale variables. You can only use categorical variables included in the boxplot.
4    Click OK in each dialog box.
Calendar with week numbers
US Federal Holidays
Australia Public Holidays
