... > Data View > Data Display
Use to represent the data with one or more data display types, including bars, symbols, and connect lines. After creating a graph, you can:
Data Display
Interval bar: Check to display a confidence interval bar. The default confidence level is 95%.
Bar: Check to display bars that join each mean to its base.
Individual symbols: Check to represent each data point with a symbol.
Mean symbol: Check to represent each mean with a symbol.
Mean connect line: Check to connect the means of grouped plots (only visible if you have categorical variables in the plot).
Median symbol: Check to represent each median with a symbol.
Median connect line: Check to connect the medians of grouped plots (only visible if you have categorical variables in the plot).
Categorical variables for attribute assignment: (Only available if a With Groups option was chosen from the graph gallery.) Enter up to four columns of grouping variables to assign different attributes to each group of the categorical x-scale variables. You can only use categorical variables included in the plot.
