1 In
the graph dialog box, click Data
View.
2 Under Data
Display, check one or more of the following:
· Interval
bar to display a confidence interval bar.
The default confidence level is 95%.
· Bar
to display bars
that join each data value to its base.
· Individual
symbols to represent each data point with a symbol.
· Mean symbol to represent
each mean
with a symbol.
· Mean connect line
to connect the means of grouped plots (only visible if you have categorical
variables in the plot).
· Median symbol to
represent each median
with a symbol.
· Median connect line
to connect
the medians of grouped plots (only visible if you have categorical variables
in the plot).
3 (Only available if a With Groups
option was selected from the graph gallery.) In Categorical
variables for attribute assignment, enter up to four columns of
grouping variables
to assign different attributes to each group of the categorical x-scale
variables. You can only use categorical variables included in the plot.
4 Click
OK in each dialog
box.
