... > Data View > Data Display
Use to represent the data with one or more data display types, including symbols, connect lines, project lines, and areas. After creating a graph, you can:
Data Display
Symbols: Check to represent each data point with a symbol.
Connect line: Check to connect the data points.
Project lines: Check to display lines that project from each data point to its base.
Area: Check to shade the area below the data points to their base.
<Regression>
