You can represent the data with symbols, connect lines, project lines, and areas. You can also fit a lowess smoother and regression line to the data. In the Example of a simple scatterplot, you examine the relationship between voltage remaining in your camera batteries immediately after a flash and the length of time required for a battery to be ready to support another flash. You want to customize the data display.
Similar data display functions are available for matrix plots. |
Symbols (default) and project lines 1 Open the worksheet BATTERIES.MTW. 2 Choose Graph > Scatterplot. 3 Choose With Groups, then click OK. 4 Under Y variables, enter FlashRecov. Under X variables, enter VoltsAfter. 5 In Categorical variables for grouping (0-3), enter Formulation. 6 Click Data View. 7 Check Project lines. 8 Click OK in each dialog box. |
Grouping variable 1 To recall the last dialog box, press [Ctrl]+[E]. 2 Click Data View. 3 Uncheck Project lines. 4 Check Connect line. 5 Click OK in each dialog box. |
