... > Scale > Axes and Ticks
Use to specify which scale elements to display and where to display them.
By default, Minitab displays the major ticks and associated tick labels for each scale on the low side of each axis. After you create a graph you can:
Axis Line: Check to display axis lines on the low sides of the x- and y-scales.
Major ticks: Check to display major ticks on the low sides of the x- and y-scales.
Major tick labels: Check to display major tick labels on the low sides of the x- and y-scales.
Minor ticks: Check to display minor ticks on the low sides of the x- and y-scales.
