1 In the data source dialog box,
click Scale, then
click the Y-Scale Type tab.
2 Under Y-Scale Type, do one of
the following:
· Choose
Frequency to change
the scale type to represent frequency.
· Choose
Percent to change
the scale type to represent percentages.
· Choose
Density to change
the scale type to represent density. Only with histograms.
· Choose
Probability to
change the scale type to represent probability. Not available with histograms.
· Choose
Score to change
the scale type to represent scores. Only with probability plots.
3 If
you have chosen Frequency
or Percent, check
Accumulate values across
bins to accumulate values from left to right with each bar. Only
4 Click
OK.
