... > Scale > Y-Scale Type
Use to choose the y-scale type of a histogram, probability plot, or Empirical CDF. By default, Minitab displays a percent scale for probability plots and empirical CDF graphs and a frequency scale for most histograms.
Y-Scale Type
Frequency: Choose to use a frequency scale. This option is only available with histograms.
Percent: Choose to use a percent scale.
Density: Choose to use a density scale. This option is only available with histograms.
Probability: Choose to use a probability scale. This option is not available with histograms.
Score: Choose to use a scores scale. This option is only available with probability plots. (For calculations, see Method of obtaining probability plot points.)
Accumulate values across bins: For histograms only, check to accumulate values from left to right with each bar. This option cannot be used with the Density option.
<Percentile Lines> (not available with histogram)
