Stat > Reliability/Survival > Distribution Analysis (Arbitrary Censoring) > Parametric Distribution Analysis > Graphs
You can draw a probability plot, a survival plot, cumulative failure plot, and a hazard plot.
Probability plot: Check to display a probability plot.
Survival plot: Check to display a survival plot.
Cumulative failure plot: Check to display a cumulative failure plot.
Display confidence intervals on above plots: Check to display confidence intervals on the probability, survival, and cumulative failure plots.
Hazard plot: Check to display a hazard plot.
Show graphs of different variables or by levels: Choose to display the graphs overlaid on the same graph or on separate graphs.
Minimum X scale: Enter a minimum value to be contained within your scale.
Maximum X scale: Enter a maximum value to be contained within your scale.
X axis label: Enter text to identify your x-axis.
