Use a probability plot to assess whether a particular distribution fits your data. The plot consists of:
For more information on probability plot calculations, see Methods and formulas - parametric distribution analysis.
Because the plot points do not depend on any distribution, they would be the same (before being transformed) for any probability plot made. The fitted line, however, differs depending on the parametric distribution chosen. So you can use the probability plot to assess whether a particular distribution fits your data. In general, the closer the points fall to the fitted line, the better the fit. Minitab provides two goodness of fit measures to help assess how the distribution fits your data.
To choose from various methods to estimate the plot points, see Tools > Options > Individual Graphs > Probability Plots. To choose from various methods to obtain the fitted line, see Parametric Distribution Analysis - Estimate.
Tip |
To quickly compare the fit of up to eleven different distributions at once, see Distribution ID Plot (Right Censoring) or Distribution ID Plot (Arbitrary Censoring). |
The Weibull probability plot below shows failure times associated with
running engine windings at a temperature of 80
