Stat > Reliability/Survival > Distribution Analysis (Right Censoring) > Parametric Distribution Analysis > Graphs
You can draw a probability plot, a survival plot, cumulative failure plot, and a hazard plot.
Probability plot: Check to display a probability plot.
Handle tied failure times by plotting
All points: Choose to plot the cumulative percents for each occurrence of a failure time.
Average (median) of tied points: Choose to plot the median cumulative percent of identical failure times.
Maximum of tied points: Choose to plot the maximum cumulative percent of identical failure times.
Survival plot: Check to display a survival plot.
Cumulative failure plot: Check to display a cumulative failure plot.
Display confidence intervals on above plots: Check to display confidence intervals on the probability, survival, and cumulative failure plots.
Hazard plot: Check to display a hazard plot.
Show graphs of different variables or by levels: Choose to display the graphs overlaid on the same graph or on separate graphs.
Minimum X scale: Enter a value for the minimum x-axis scale.
Maximum X scale: Enter a value for the maximum x-axis scale.
X axis label: To replace the default x-axis label, type the text in this box.
To change the method for calculating probability plot points, see Tools > Options > Individual Graphs > Probability Plots. |
