1 In the main dialog box, click Options.
2 If Least Squares is your estimation method, choose Use historical estimates.
If Maximum Likelihood is your estimation method, choose one of the following:
3 If you choose Estimate parameters of distribution, you can do any of the following:
- In Use starting estimates, enter columns of starting values based on your data structure. See Starting estimates for more information.
- In Maximum number of iterations, enter a positive integer to specify the maximum number of iterations for estimation.
4 If you choose Use historical estimates,
- Enter columns of historical values based on your data structure. See Historical estimates for more information.
5 Click OK.
