Acceptance Sampling by Attributes - CompareUser Defined Plans - Sample Size and Acceptance Number |
You can compare plans by varying the sample size, the accept number, or both together.
Compare User Defined Plan(s)
Sample Acceptance Percent Probability Probability Size(n) Number(c) Defective Accepting Rejecting AOQ ATI 150 10 2 1.000 0.000 1.988 155.9 150 10 5 0.868 0.132 4.313 3435.6
200 10 2 0.997 0.003 1.979 262.8 200 10 5 0.583 0.417 2.892 10539.9
250 10 2 0.987 0.013 1.955 566.7 250 10 5 0.291 0.709 1.440 17799.6
Sample Acceptance At Percent Size(n) Number(c) AOQL Defective 150 10 4.355 5.369 200 10 3.254 4.027 250 10 2.595 3.222
Accept lot if defective items in n sampled ≤ c; Otherwise reject. |
Using your specifications for lot size, AQL, RQL, producer's risk (alpha), and consumer's risk, Minitab determines that an appropriate sampling plan is to inspect 306 bags. You wish to investigate the risks associated with sampling 150, 200, or 250 bags, using the same accept number of 10 at the AQL and RQL levels.
