Acceptance Sampling by Variables - CompareUser-Defined Plans - Average Outgoing Quality (AOQ) |
The average outgoing quality level represents the relationship between the quality of the incoming material and the quality of the outgoing material, assuming that rejected lots will be 100% inspected and all defective items will be replaced or reworked.
As the defect level of the incoming parts increases, the inherent quality of the accepted lots decreases; however, the number of rejected lots also increases. The sorting of the bad parts (100% inspection and removal) helps the outgoing quality level, but at a high cost. The maximum possible defect level, an important characteristic of the sampling plan, is the average outgoing quality limit (AOQL).
Compare User Defined Plan(s)
Sample Critical Defectives Probability Probability Size(n) Distance(k) Per Million Accepting Rejecting AOQ ATI 100 3.44914 100 0.854 0.146 83.0 612.3 100 3.44914 600 0.224 0.776 130.8 2815.1
150 3.44914 100 0.899 0.101 86.1 500.1 150 3.44914 600 0.172 0.828 98.8 3007.3
200 3.44914 100 0.928 0.072 87.6 444.7 200 3.44914 600 0.135 0.865 76.3 3142.0
Sample Critical Maximum At Defectives Size Distance(k) StDev(MSD) AOQL Per Million 100 3.44914 0.0027533 145.6 369.7 150 3.44914 0.0027533 138.5 288.9 200 3.44914 0.0027533 136.7 256.4
Z.LSL = (mean - lower spec)/standard deviation Z.USL = (upper spec - mean)/standard deviation Accept lot if standard deviation ≤ MSD, Z.LSL ≥ k and Z.USL ≥ k; otherwise reject. |
For the camera data, when the average incoming quality level is 100 defectives per million, the average outgoing quality is 83.0, 86.1, and 87.6 defectives per million, when the sample sizes are 100, 150, and 200 and the critical distance is 3.44914. When the average incoming quality level is 600 defectives per million, the average outgoing quality is 130.8, 98.8, and 76.3 defectives per million, when the sample sizes are 100, 150, and 200 and the critical distance is 3.44914.
Keeping the critical distance at 3.44914:
As the sample size decreases, the number of rejected lots with all defects removed also decreases, so the quality gets worse. This results in a higher average outgoing quality limit.
