Acceptance Sampling by Variables - CompareUser-Defined Plans - Average Total Inspection (ATI) |
The average total inspection per lot represents the relationship between the quality of the incoming material and the number of items that need to be inspected, assuming that rejected lots will be 100% inspected and defective items will be reworked and inspected again (rectifying inspection).
Compare User Defined Plan(s)
Sample Critical Defectives Probability Probability Size(n) Distance(k) Per Million Accepting Rejecting AOQ ATI 100 3.44914 100 0.854 0.146 83.0 612.3 100 3.44914 600 0.224 0.776 130.8 2815.1
150 3.44914 100 0.899 0.101 86.1 500.1 150 3.44914 600 0.172 0.828 98.8 3007.3
200 3.44914 100 0.928 0.072 87.6 444.7 200 3.44914 600 0.135 0.865 76.3 3142.0
Sample Critical Maximum At Defectives Size Distance(k) StDev(MSD) AOQL Per Million 100 3.44914 0.0027533 145.6 369.7 150 3.44914 0.0027533 138.5 288.9 200 3.44914 0.0027533 136.7 256.4
Z.LSL = (mean - lower spec)/standard deviation Z.USL = (upper spec - mean)/standard deviation Accept lot if standard deviation ≤ MSD, Z.LSL ≥ k and Z.USL ≥ k; otherwise reject. |
For the camera data, when the average incoming quality level is 100 defectives per million, the average number of lenses inspected per lot is 612.3, 500.1, and 444.7, when the sample sizes are 100, 150, and 200 and the critical distance is 3.44914. When the average incoming quality level is 600 defectives per million, the average number of lenses inspected per lot is 2815.1, 3007.3, and 3142.0, when the sample sizes are 100, 150, and 200 and the critical distance is 3.44914.
