Stat > Quality Tools > Capability Sixpack > Between/Within > Options
Allows you to control display settings and set target and tolerance values to use for computing capability indices.
You can set global preferences for the sigma tolerance and the display defaults for the capability statistics using Tools > Options > Control Charts and Quality Tools > Capability Analysis.
Target (add Cpm to table): Enter a number that Minitab uses as a target. Minitab then calculates Cpm, in addition to the standard capability statistics, displaying the target and Cpm values in a table below the graph.
Use tolerance K*sigma for capability statistics K= Enter a number (default is 6.0) to calculate the capability statistics using an interval other than 6 standard deviations wide (3 on each side of the process mean). Minitab interprets this value as a two-sided tolerance. If you want to use a one-sided tolerance, enter a two-sided tolerance value that is twice that of your one-sided tolerance. For example, if you want a one-sided tolerance of 3 sigma, enter 6.
Display
Capability stats (Cp, Pp): Choose to display the Cp and Pp values.
Benchmark Z's (sigma level): Choose to display the within and overall Zbench values.
Title: To replace the default title with your own custom title, type the desired text in this box.
