Options - Tests
    how to     see also
Stat > Control Charts > Rare Event Charts > T > T chart Options > Tests
Selects a subset of the tests shown in Eight Tests for Special Causes. Each test detects a specific pattern in the data that is plotted on the chart. The occurrence of a pattern suggests a special cause for the variation, a cause that should be investigated.
For the traditional control charts for variables data, Tests 1, 5, 6, 7 and 8 are based on the normal distribution. However, for T charts, these tests are based on the Weibull distribution or the exponential distribution. For example, a point on a T chart fails Test 1 when the point is outside of the percentile range that correspond to 3 standard deviations from the mean for a normal distribution. See Methods and Formulas for more information.
When a point fails a test, Minitab marks the point with the test number on the plot. If a point fails more than one test, Minitab marks the point by the lowest numbered test.
You can choose to change the color of a control chart when the last row of data causes a new test failure for any point. See Tools > Options > Control Charts and Quality Tools > Other.
You can set preferences for the sensitivity of these tests using Tools > Options > Control Charts and Quality Tools > Tests.
The test results are displayed in the Session window. If the data change and the control chart is live-linked, the test results are not updated in the Session window. See Updating Graphs for more information.
See [1] and [32] for guidance on using these tests.
Tip
Minitab recommends that you use both Test 1 and Test 2 when you create a T chart because the T chart may be slow to detect small to moderate decreases in the average time between events.
Tests For Special Causes (default definitions):
Perform all tests for special causes: Choose to perform all eight tests shown below.
Perform selected tests for special causes: Choose to specify a subset of the eight tests, then check any combination of the tests listed below. You may customize particular tests by changing the values of K.
K
1 point more than K standard deviations from center line
K determines where the control limits are drawn on the chart.
K points in a row on same side of center line
K points in a row, all increasing or all decreasing
K points in a row, alternating up and down
K out of K + 1 points > 2 standard deviations from center line (same side)
K out of K + 1 points > 1 standard deviation from center line (same side)
K points in a row within 1 standard deviation of center line (either side)
K points in a row > 1 standard deviation from center line (either side)
Perform no tests: Choose to perform no tests for special causes.
Create Pareto chart
