... > control chart Options > Limits
Charts Individuals, Moving Range
Allows you to draw control limits above and below the mean at the multiples of any standard deviation. You can set bounds on the upper and/or lower control limits. When the calculated upper control limit is greater than the upper bound, a horizontal line labeled UB is drawn at the upper bound instead. Similarly, if the calculated lower control limit is less than the lower bound, a horizontal line labeled LB is drawn at the lower bound instead.
For an example, see Example of an X chart with tests and customized control limits.
Tip |
You can also modify the control limits using Minitab's graph editing features. |
Display additional sigma limits at
These multiples of the standard deviation: Enter one or more values. The values entered are the number of standard deviations above and below the center line. If you specify more than one value, a pair of control limits is drawn for each value in the list.
Place bounds on control limits
Lower standard deviation limit bound: Check to set a lower bound for the control limits. If the calculated lower control limit is less than the lower bound, a horizontal line labeled LB will be drawn at the lower bound instead.
Upper standard deviation limit bound: Check to set an upper bound for the control limits. If the calculated upper control limit is greater than the upper bound, a horizontal line labeled UB will be drawn at the upper bound instead.
