Z-MR Options - Storage
    how to
Stat > Control Charts > Variables Charts for Individuals > Z-MR > Z-MR Options > Storage
Use to store your choice of statistics in the worksheet.
Store these estimates for each chart
Means: Check to store the estimates of the means, one row for each historical stage.
Standard deviations: Check to store the estimates of the standard deviations, one row for each stage.
Store these values for each point
Point plotted: Check to store the plotted points, one row for each plotted point.
Center line value: Check to store the center line value, one row for each plotted point.
Control limit values: Check to store the control limit values, one row for each plotted point. Minitab stores one column for the lower control limit and one column for the upper control limit.
Test results: Check to store the results of any test performed, one row for each plotted point.
