Stat > DOE > Factorial > Analyze Variability > Graphs
You can display effects plots and residual plots for ratio, log, or standardized log residuals.
Effects Plots
Normal: Check to display a normal probability plot of the effects.
Half Normal: Check to display a half normal plot of the effects.
Pareto: Check to display a Pareto chart of the effects.
Residuals for Plots
Ratio: Choose to plot the ratio residuals.
Ln: Choose to plot the log residuals.
Standardized ln: Choose to plot the standardized log residuals.
Residual Plots
Individual plots: Choose to display one or more residual plots.
Histogram: Check to display a histogram of the residuals.
Residuals versus order: Check to plot the residuals versus the order of the data in the run order column. The run order for each data point is shown on the x-axis - for example, 1 2 3 4... n.
Three in one: Choose to display a layout of a histogram of the residuals, a plot of residuals versus fits, and a plot of residuals versus order.
Residuals versus variables: Check to display residuals versus selected variables, then enter one or more columns. Minitab displays a separate graph for each column.
