1 Choose Stat > DOE > Factorial > Response Optimizer.
2 For each response, complete the table as follows: (If an expected response column does not show in Response, fit a model to it.)
3 Click Setup.
4 For each response, accept the defaults or enter your own values:
1 If you choose Minimize under Goal, enter values in Target and Upper.
2 If you choose Target under Goal, enter values in Lower, Target, and Upper.
3 If you choose Maximize under Goal, enter values in Target and Lower.
For guidance on choosing bounds, see Specifying bounds.
5 Click OK.
6 If you like, use any of the available dialog box options, then click OK.
