1 In the Create Mixture Design dialog box, click Process Vars.
2 Under Process Variables, choose Number, then choose a value from 1 to 7.
3 From Type of design, choose a full or fractional factorial design. The available designs depend on the number of process variables chosen.
4 If you like, you can select the fraction number you want to use. By default, Minitab uses the principal fraction. See Choosing a fraction.
5 If you like, you can name the process variables and set the process variable levels.
6 Click OK.
